How do I enable DAQ Assistant in LabView Student Edition?
Hello.  I'm using Lab View 7.1.1 Student Edition with a PCI-4472 ADC and PCI-6711 ADC.  I'm attempting to use the Daq Assistant according to a tutorial I found on the NI site.
Unfotunately I have no DAQ Assistant option.  I found some documentation suggesting that I needed the NI Device driver CD available from the FTP site.  However this only contained outdated versions of the DAQmx (I had version 😎 and VISA programs, which I have already installed.  To be sure, I installed it anyway, but with no change.
At this point I don't understand why I am having such trouble with the DAQ Assistant.  In my previous experience with LabView elsewhere, the feature just worked.
Thanks.
Message 1 of 8
(5,925 Views)
DAQmx 8 is what you need for the DAQ Assistant and all DAQ related functions and it is available for download here.
Before you get to deep into the DAQ Assistant, try looking through the Exmaple VIs (Help menu>Find Examples) to see how to do data acquisition without the DAQ Assistant. The DAQ Assistant is OK for something quick you're not going to save and reuse, but if you're building an application, you should learn how to use teh DAQmx VIs correctly.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 2 of 8
(5,924 Views)
Ed
Thanks, but as I said above I already have the DAQmx 8 software installed and still do not have the DAQ Assistant available.
I'll look into not using the DAQ Assistant, but the fact that its missing makes me worry that some part of my software is not configured properly. Could someone clarify this point for me?
Message 3 of 8
(5,919 Views)
Sorry, I missed the part where you said you already had it installed. I must be reading too fast.
Any version of DAQmx will give you the DAQ Assistant. You should be able to find it two spots as shown in the images below.
If they're not there, something didn't go right during the install. You could try uninstalling and reinstalling.
Let us know how it works out.
Ed
Message Edited by Ed Dickens on 12-20-2005 01:15 PM
Message 4 of 8
(5,920 Views)
Thanks for the help.  My Input menu just does not have the DAQ Assist:
I think I have some idea why.  I tried out the example browser as suggested, and none of the VIs in it work.  It claims that it can't find the file.  However the files do exist on my hard disk in the proper directory.  This is pretty normal for me, I just formatted and am now reinstalling because I had this problem on the previous install.  But more interesting, if I browse and run the VI directly, it starts to load, but is missing DAQmx files:
In fact, that entire folder does not exist!
Can someone shed some light on the issue?  Although the entire DAQmx folder is missing, I really do have DAQmx 8 installed, and I can even load up Measurement and Automation Explorer, browse to DAQmx devices and view the input from my function generator.
Thanks again.
Message 5 of 8
(5,913 Views)
If you don't have the DAQmx directory in the vi.lib directory, the install definately didn't go right.
I'd try uninstalling DAQmx, download a new copy and reinstall.
If that doesn't do it, I'm pretty much at a loss. I've seen some other threads having a similar problem. I'll try and find them and see what happened.
Ed
Message 6 of 8
(5,908 Views)
I got it. You were right. It was an install issue. I wiped out all trace of DAQmx, made sure LabView was still working, and then installed the same DAQmx again. It works now! Uninstalling it was the key, it didn't work if I just did a reinstall.
Thanks so much Ed.
Message 7 of 8
(5,901 Views)
Glad you got it.
Thanks for letting us know.
Ed
Message 8 of 8
(5,890 Views)
