How do I enable the following private functions in labview 2014? SuperPrivateScriptingFeatureVisible and SuperSecretPrivateSpecialStuff
Hello guys,
I need to access private functions that previously used labview in 2011, but that version of 2014 not found, can help me?
thanks
(7,986 Views)
Here's a start:
Jim
(7,969 Views)
But that's not what I'm looking
(7,939 Views)
Well you can probably just try, it doesn't take much to put it in your INI and see if it works.
That being said the INI key hasn't changed I'm using the same one I was from 2011 to 2015.  And before I give out this information I feel obligated to say:  NI does not want anyone using private methods other than NI.  They might expose incomplete functions, undocumented experiences, and their functions may change without notice in future versions of LabVIEW.  Use at your own risk, and you will not get support from NI for using these functions, unless you have an agreement with NI that they will.
So for me the key is:
SuperSecretPrivateSpecialStuff=True
But if it is too hard to remember, I made a tools menu item for it on LAVA.
(7,918 Views)
Maybe it's one of these:
SuperPrivateScriptingFeatureVisible=True
SuperPrivateSpecialStuff=TRUE
SuperSecretListboxStuff=True
SuperSecretCLAFeatures=True
AdvancedPlotLegendMenu=True
enableSecretPopups=True
(7,889 Views)
Or maybe these:
ActiveXMoreContainerOptions=True
TotallySecretAndPrivateMSNCompanionDiagram=True
(7,884 Views)
