How do I enter a simple equation in labview
  dN/dt = flux*fission rate* cross-section for absorption - decay rate * N? I am using a formula block X1*X1*X3-X4 where X4 is the output of the derivative time the decay constant. Should I be using the dervative or integral.Thanks
(4,194 Views)
So are you wanting to know what to enter, or as the subject says, how to enter it? Can you explain a bit more of what you are trying to accomplish?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,146 Views)
He's kind of split this into two posts.  He's posted some code via dropbox in his other post (assuming the two are related).
Here's his other post
(4,133 Views)
I saw the other post after I responded to this one. I won't download things from an anonymous drop box either.
Mike...
LabVIEW Champion
(4,026 Views)
Thank you for trying to help. It was my first post. I reposted this evening with an attachment which shows what I tried to do.
(3,937 Views)
Thank you. Yes my posts were related. It was my first post and I was having trouble attaching my screen shot. I hope my newer post is clearer. Hoping to learn what to do, Kyle
(3,935 Views)
Attaching an actual vi is generally prefered over a picture by the folks here on the forums.  If the vi's aren't being attached properly, it is recommended to try zipping them, even if you are only trying to post a single vi.
(3,851 Views)
