How do I enter data into an imaq image directly in C
I want to write data into an imaq image. The image is created in Labview 7.1, but I need to enter the data in C. Therefore I want to pass the pointer to the image pixels to a dll where I simply step through the image pixels, writing its value directly. However, I'm not sure how to go about this properly - I tried something similar to the example for GetImagePixelPntr, but I don't want to copy the data as this wastes time. Surely it must be possible to write the data into memory once (i.e. the memory where the image is stored).
A simple example would be great (e.g. write a blob into the image structure via passing the pointer to a C dll and using a for loop to write the image data).
I need to do this because I have a usb camera with C code which simply writes the camera pixels into memory by passing a pointer to the memory address to the C function. However, I want to make use of the IMAQ functions. I may also need to do some of my own pixel processing in C, and again I don't want to make copies of the data, but to manipulate it directly.
Thanks for any help
(2,664 Views)
Hi Wybird,
It may be useful for you to look at this link.  It provides a number of third party drives and some software to allow you to place the image direcly into LabVIEW where a lot of the image manipulation can be performed.
http://digital.ni.com/public.nsf/allkb/274A74A901399D0486256F32007295F9
It may also be helpful too take a look at , search through, the Machine vision forums.  There are a lot more detailed vision forum questions and answers that may help with your application.
Post back if you require any other onformation
AdamB
NIUK
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,654 Views)
Hello again,
Just revisited your problem and a colleague of mine has posted this link.  It may be very useful.
http://forums.ni.com/ni/board/message?board.id=170&message.id=150718
Regards
AdamB
NIUK
(2,639 Views)
