How do I extract time from DAQ Assistent?
Hi!
I've done an application acquiring two voltages using the DAQ assistent.
Everything works fine. Now I would like to extract the time for each sample,
how do I do that? The output from the DAQ assistent i DDT. If I save the
DDT-output directly to an lvm-file I get the time correctly. But I would like to
extract the time and use it in my software.
Thanks for any help!
Mattias Ottosson
(3,904 Views)
Try the from DDT express VI from the Express->Signal Manipulation palette (LV8.0).  This should convert it to a waveform, at which point you can extract the t0 and get your time.
(3,896 Views)
Thanks for your help. So if understood correctly I will get td and t0.
Is there any way to get the time for each sample, or should I just create an array
of timestamps starting at t0 and increasing by td? Using this way I must assume
that each sample is sampled with the same td, is this true? I use the DAQ assistent
as: Acquisition mode = N samples, N=100, Samplingfrequency= 1kHz. USB-6009.
Thanks again for your good help.
(3,891 Views)
Hello!
Yes you can assume that it has the same dt between each sample since you have a clock on the device that controls the acquisition (24MHz timebase if I am not mistaken).
The picture below shows how it can look like when extracting the t0 and dt in LabVIEW.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,878 Views)
The solution seems very easy when you know how to do it 🙂
Thank you for your kind help.
Regards
Mattias
(3,873 Views)
