How do I find out what the internal error was?
I got a fatal internal error when I pressed the "Show Errors" button under Windows->Show Errors menu option.
Silly me, I didn't write it down. When I relaunched LabView, it offered to go and try to diagnose the error,
but not I can't find any trace of what the error actually was! Obviously, I should have written it down,
but why didn't Labview also record the error?
(2,559 Views)
Hi Doughera!
When you say: "When I relaunched LabView, it offered to go and try to diagnose the error", do you mean that LabVIEW gave you the option of Investigate Now, Investigate Later, & Do Not Investigate? Assuming this is what you are referring to, by choosing either Investigate Now or Investigate Later, LabVIEW will generate an error log .txt file. This file is automatically placed in your My Documents\LabVIEW Data\lvfailurelog folder.
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
(2,547 Views)
