How do I flush the serial port buffer?
To initialise a piece of hardware I need to flush the serial port buffer.
Any advice please?
Many thanks.
(12,923 Views)
There is a "windows Flush com buffers.vi", hidden away in the _sersup.llb. Usefull?
(12,923 Views)
Do you need to flush the serial buffers on the PC or in the device you're talking to? If you are wanting to flush the serial buffer on your end, the buffers are automatically flushed when the port is initialized. In addition, you can flush the receive buffer at anytime by reading the number of bytes at the port and (if not zero) reading that number of bytes.
If the serial buffer on the other machine needs flushing, that's a pretty device-specific issue. What are you trying to talk to?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(12,923 Views)
Mike...
LabVIEW Champion
(12,923 Views)
mikeporter wrote in message news:<5065000000050000002C700000-1017707437000@exchange.ni.com>...
> Mike...
Hi, I am using the parallel port to communicate. And I don't know if
it is the same with the serial port, but you can always try I
thought....
If I use a VISA vi (e.g. write)in Labview in need to flush the buffe
of the PC afterwards, because otherwise the old data stays in the
buffer, even if I write new data to the port. To flush the buffer can
be done with the vi: VISA flush serial buffer. (though it is for the
serial buffer, it also flushes the parallel buffer). But when I am
using the Out Port vi, I don't need to flush the buffer, because it
writes directly to the port, and every time you write new data it
overwrites the old data.
And very important! When I flush the buffer all the pins (all data,
control, status pins) are set to there "normal" state. And with the
Out Port they don't.
I hope you can use this information
Greetz,
JJ
(12,923 Views)
