How do I get Scaled Coefficients for the FPGA version of the Butterworth Filter
I am trying to program an FPGA application where I need to be able to change the filter cutoff frequency.  I see that I can make a terminal for the filter coefficients on the Butterworth Filter express VI, but how do I generate those filter coefficents for different cutoff frequencies?  When I use the Butterworth Coefficients VI on the host side it returns small floating point values rather than the large fixed point values that I am seeing on the FPGA side.
David R. Asher
Certified LabVIEW Architect since 2007
(3,977 Views)
Accepted by topic author David_R._Asher
Hi David,
In 8.5 or 8.6, there is a shipping example that contains the filter design subVI you need:
examples\R Series\FPGA Fundamentals\Analysis and Control\Filter and DC-RMS\Using Reconfigurable Butterworth Filter - R-series.lvproj
In LabVIEW 2009, there is a new palette under My Computer: FPGA Interface>>Scaling, with a new Butterworth Coefficients VI on it. That will produce the quantized coefficients you need in the format expected by the FPGA Butterworth Filter.
Jim
(3,962 Views)
