How do I get a 5 MHz plot from a spectrum analyzer to a VI?
Dennis_Knutson,
I downloaded the LabVIEW 8 Legacy Instrument Driver. The download provided a folder with several VIs. However, all the VIs start with "RSFSU" and the example VI is looking for sub-VIs that start with "rsspecan." So the example VI won't use any of the sub-VIs in the download. Not sure what I am doing wrong here.
Thank you,
Ian
Message 11 of 15
(816 Views)
The NI Instrument Driver Network points to http://www.rohde-schwarz.com/en/driver/fsu/
Perhaps that will work better.
Message 12 of 15
(803 Views)
Hi Dennis,
Thank you for your responses. I am still prettly lost however.
The link you provided list 7 drivers. The readme file for the example VI states the prerequisit is "rsspecan LabVIEW Instrument Driver." None of the 7 drivers listed on the page match that name. I tried a few of the drivers, but nothing seemed to work. Which driver should I download? Is there something other than just downloading the driver and installling it that I need to do. I am honestly confused as to how a driver even provides sub-VIs. Do I need to point LabVIEW towards the driver?
Thank you again,
Ian
Message 13 of 15
(793 Views)
One of the 7 is called LabVIEW 2010 rsspecan.
The main NI driver page has links that explain what a driver is and how to use one.
http://www.ni.com/downloads/instrument-drivers/
Message 14 of 15
(790 Views)
Thank you Dennis,
I was saving the driver folder in the wrong location, so LabVIEW could not find the sub-VIs. I got the example to open correctly.
Ian
Message 15 of 15
(766 Views)
