How do I get a BNC 2121 to produce a milisecond counter as an out?
I am trying to get a milisecond counter out of the BNC2121.
(2,695 Views)
Thank you for contacting National Instruments. The BNC 2121 is normally used as an accessory for a PCI/PXI-660x counter timer board. Assuming that you are using one of these boards you will have to write a simple program in LabVIEW or any other programming tool that you are using that generates a pulse every millisecond. You should be able to find examples that will get you started.
Nipun M
(2,695 Views)
