How do I get a Value out of a XY Graph
Hey there,
I am pretty new to LabView and i hope you can help me out.
I got 2 Arrays both of them got 3 Values and i managed to put them in a XY Graph.
Here is my issue, I want a y value for the corresponding x.
Is there any way to get to that graph data?
Thank you for your efforts in advance.
(4,266 Views)
You have to feed values into the xy-graph.  Split that wire and bring the data into your logic to get the matching pair.  You already have the dta.  Don't overthink this
(4,255 Views)
Yes, but how you do it depends on the datatype of that data driving the graph. You see, an XY graph can plot data in more than 1 format.
Can we see you code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,251 Views)
Yeah sure, here is my code, its a little bit messy as for now but I think you get what i want.
Its about a temprature meassurement, here is my idea:
I meassured 3 different temperatures and the corresponding Measured Resistance.
Now I got a y value for
9 30 45
plotted the graph -> and now i want a y value for lets say -5 or 15
But i have a hard time actually getting these informations
(4,213 Views)
Accepted by topic author Wollny91
Unless your DAQ data is quantized to the three possble X values, you need to interpolate. You already have made a linear fit, so all you need to do is feed the new x value into "linear evaluation" and get the corresponding y value. Of course you could equally well use e.g. a quadratic polynomial. (For higher orders, you would need more points).
(4,203 Views)
OFC thank you so much, i def. overthought that way to much.
It is way easier than i thought it would be.
(4,185 Views)
