How do I get a digital output (+5V) from a PXI-6704 if it is connected to a SCB-68?
I would like to be able to use the Digital output to send TTL signals to a controller to overide any analog inputs it is receiving.
(2,781 Views)
Assuming you are using LabVIEW, it is possible to update the state of the individual digital lines (8 in total DIO0-7) on the PXI-6704 using the Write To Digital Line VI. With this VI you simply specify the line number (0-7) and the state (T/F).
Alternatively if you wish to update all 8 lines at the same time, you can use Write To Digital Port. In this instance the number you pass to the VI will determine to state of all 8 bits. For example, pass the value 141 (decimal) = 8D (hex) = 10001101 (binary) will set lines DIO0,2,3,7 HIGH and the rest LOW.
You can also create virtual channels for individual lines or the complete 8-bit port using the Measurement & Automation Explorer.
Jeremy
(2,781 Views)
Forgot to mention that the DIO lines can be found on pins 2-9 of the SCB-68 with reference to DGND (several available including pin 35). The PXI-6704 User Manual has more information about signal connections and considerations for hooking these lines up to external equipment.
Jeremy
(2,781 Views)
