How do I get context help for my subVIs' terminals?
I have created subVIs in which I filled in their "Description and Tip..." fields for their terminals. However when they are in a block diagram and I show their Context Help, the terminal names show up but there is no "Detailed Help" link like with the VIs shipping with LabVIEW.
How do I get these terminals' descriptions in that Context Help window?
(3,863 Views)
That extra help information gets entered in the VI's documentation. From the VI, go to "File -> VI Properties" (or ctrl-I), Documentation tab.
(3,851 Views)
I am looking at that "File -> VI Properties" tab for one of NI's built-in VIs, "LabVIEW 2012\vi.lib\Instr\_visa.llb\VISA Configure Serial Port (Instr).vi".
I only see three fields:
  1. VI description
  2. Help tag
  3. Help path
"Help path" refers to a CHM file which, when I open it, looks like it can use the information in "Help tag" to populate that window.
It looks like I need to learn how to construct CHM file compatible with LabVIEW help....
Is this documented somewhere? LabVIEW Help and Google are failing me on this topic of CHM.
(3,834 Views)
