How do I get my NI-DAQ configuration utility to recognize my PCI-6017E card?
I'm having a lot of trouble with my PCI-6017E card. I'm running Windows 98, and NI-DAQ 4.0.9f. These configurations can't be changed because I need them to run another DAQ card. However, when I insert this new card, the system will recognize the PCI card, however, it does not have the drivers for it. It is also not listed at all in the Device manager. I have already gone through the troubleshooting advice, and it doesn't work. The card will also not show up in the NI-DAQ configuration utility. Is my version of NI-DAQ not compatible with this card? Thanks for helping!!!
Jen
(3,394 Views)
Actually, I meant PCI-6071E. Sorry, I switched the numbers. Also, the connector is the AT-MIO-64E3.
Jen
(3,394 Views)
Jen;
The first version of NI-DAQ compatible with your device is 5.1.1. That is the reason for you to see that beviour.
Hope this helps.
Filipe
(3,394 Views)
Thanks! That really helps.
Jen
(3,394 Views)
