How do I get past Error 1913 when installing LabVIEW 7 Express
I get this error, yet I can see the file in the exact location the error tells me to locate it in. Apparently LabVIEW 7 does not create the labview.ini file. The file I see present was copied from LabView 6.
(2,684 Views)
Are you trying to install to a mapped network drive? This is not supported so could be the cause. It could also be that you are trying to install on a NT/2000/XP machine in which case you need to have local administrator rights to be able to write to this file.
Hope this helps,
Nick
(2,684 Views)
