How do I get rid of just spaces in a string?
Hi
My question is, How do I get rid of spaces in a string and replace it with a tab?
Eg
.2.27.....0.99999 to
.2.27 0.9999
Thank you
Message 1 of 8
(3,510 Views)
Remove space(s) from the input string.
Result string is tab separated.
LabVIEW 7.0
labview@ianfung.net
20050506
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 8
(3,508 Views)
Hi
I tried it out but it has not worked. This is what I get(see attached)
Message 3 of 8
(3,505 Views)
Perhaps, it would help if you could provide us a real case as of what is your input string, and what you are expecting to see.
Thanks.
Ian F
依恩与LabVIEW
Message 4 of 8
(3,499 Views)
Do you just want to replace spaces with tabs?
If so, use this code:
Message 5 of 8
(3,485 Views)
Thanks.
Hi
I have edited the attachement with the type of data that we are dealing with. In some of these files there is a mixture of tabs and spaces delimiting the data. It would be nice if we can have only one tab delimiting the data. Also get rid of the space in front of the first number.
Thank you
Message 6 of 8
(3,454 Views)
@adrianT wrote:
Thanks.
Hi
Thank you
Oops !!!
I thought I saved the file.
Here is the good one.
Message 7 of 8
(3,444 Views)
A simple one...
CC
Chilly Charly    (aka CC)
Message 8 of 8
(3,438 Views)
