How do I get the chart to start from ZERO?
Hello everyone,
Could anybody tell me if it's possible to use a chart that shows the acquisition since Time Zero ( instead of moving forward ) ?
Thanks a lot,
Marc
(3,302 Views)
You have to set a suitable chart history length ( based on number of Points you want to display on your chart) and selecting the x axis scale 'start' as 0 and 'end' as ( chart history length-1)
Also, disable autoscale X axis in the pop down menu of your Chart
(3,298 Views)
Hi devchander,
Thank you very much for your answer. I was actually wondering if it was possible to have a chart that needn't to have to set it's history length. The last data would be plot at the end of the history ( so that the length of the history changes it self). I am not sure I am very clear... lol
Do u know if this exists...?
Marc
(3,251 Views)
That would be a graph, but you would have to build your own 'history' and feeding each run all the data. With LabVIEW 8 and a x-control it would be possible. but you would fill all the available memory of the PC!
Ton
My LabVIEW Ideas
(3,244 Views)
Hi Ton,
Thanks for ur answer !
Marc
(3,216 Views)
