How do I get the last COLUMN in an Excel Sheet using Report Generation toolkit in LV7.1?
I am trying to get the last column in an Excel sheet using the Report Generation toolkit. The function "Excel Get Last Row" does not give last column info. Is there a function that will do this?
(2,840 Views)
Hello –
I think the following example program might be helpful to get you started programming your application.
Get Excel Data from Specified Field.
Hope this helps!
SVences
(2,823 Views)
