How do I get the tools palette to be visible in labview 7? It is not listed under windows
The winow dropdown list does not even list "show tools pallete". The auto tool is driving me crazy
(3,199 Views)
I encoutnered the same thing today....
It IS listed, but LV 7 has the annoying "auto hide" function for removing less-frequently used menu entries. Simply move to the very bottom of the menu to expand it and reveal the otherwise hidden entries. Then you should see the option for the tools palette.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,199 Views)
this feature can be turned off quite easily...
Tools --> Options --> Miscellaneous uncheck Use Abridged Menus
good luck
(3,199 Views)
I'd turn this option off as the others pointed out. It is annoying.
You can also get the Tools palette by holding the 'Shift' key down while right-clicking. This works on both front panel and block diagram. This is nice to know if you use the auto tool as it's a quick way to get to the tool palette.
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,199 Views)
