How do I get these to reappear?
When I put the value 01 on the combo box, I want 1 boolean to appear, when I put 02 I want two booleans to appear and so on...
What am I doing wrong?
mhaque
(2,868 Views)
Accepted by topic author mhaque
You never set any of them to be visible again, you just hide the ones you don't want to see.  Try putting one "Visible" property node for each boolean outside the case structure, then wire a value to each one from within every case of the case structure.  In the case "1" you'd wire one true value and five false values; in the case "6" you'd wire six true values (or one true constant, with the wire branched to six tunnels).
(2,862 Views)
A cleaner way to do what you want.
(2,851 Views)
daaaaaaaaaamnnnn that was gangstaaa!!! awesome!
(2,845 Views)
