How do I graph repetitive interleaved samples in Labview
I am using Random Interleaved Sampling and I am trying to graph the output in LabView 8.21.  I have tried sending the waveform to a waveform graph and it is just clearing between each loop.  I have also tried to build a waveform using the build waveform function and a feedback node to try to interleave the current results with the previous but it doesn't seem to be working either.  If I just graph the waveform directly, the graph clears automatically.  How can I plot the results without the graph clearing or build a dynamic cluster of waveforms with the data interleaved within?
Message 1 of 1
(2,610 Views)
