How do I have data from a 2D array look the same way on the table?
I appologize for not attaching my code, It's extremely large.  So I thought it would be best to focus on what I need help with.
I captured a screenshot of the part of my code I need help with.
 I tried to to turn "stick 1D array" into 2D array. Note: This code is in the state machine.
Below is the result I am getting. I just want the numbers on the table to look the numbers in the array. I know a long way to do it, but does anyone know a short cut by any chance? I tried to change precision from "number to fractional string" block, it didn't work for me. Any suggestions?
(1,163 Views)
You can use "format into string", but you need to wrap two autoindexing for loop around it.
(Right-click your array elements and see what their format is, then use that.)
(1,134 Views)
You could feed the double array to 'Array To Spreadsheet String' followed by 'Spreadsheet String To Array' with a 2D string constant as array type input. 'Format string' could be %0.7f.
(1,085 Views)
or %#.7f
Spoiler
(1,076 Views)
