How do I have my VI prompt me to create a file?
So I have a block diagram that saves csv file every 30 seconds. So Before I even start running, I would like my block diagram to prompt me to  save a file by bring file explorer as shown below without messing up the functionality of my block diagram. I still want to be able to save the same file I am creating every 30 seconds.
I try messing with the property of the base path. I'm still unable to have my VI prompt me. I have tried using case structure before to create an initial file on another code I have and it has never worked for me.
Can someone please help me?
Message 1 of 9
(2,512 Views)
Have you tried an action engine? Create an INIT case and have it initialize the save file prompt. You would still need to run the VI but it would force the VI to ask the user if they would like to save a file and handle that action prior to any further movement.
Creig Mills
Culverson.com
Message 2 of 9
(2,503 Views)
You need to change the "browse option" (right-click) of your path control to allow selecting new files. (You currently have it to allow only the selection of existing files)
(You still use inner loops to gum up your dataflow. Just don't!)
Message 3 of 9
(2,479 Views)
No, I have not. Does NI have an example for that?
Message 4 of 9
(2,474 Views)
Good morning Mr. Altenbach
I tried switching to New and I still don't have file explorer prompted.
Yes, I have to stop using these inner loops. I'll just stick with state machine.
Message 5 of 9
(2,473 Views)
Accepted by topic author GRCK5000
That's when you would press on the browse button next to the path control.
To prompt the user at runtime, call the "file dialog" function where you have all the same options. Make sure to also handle the situation where the user cancels the file dialog.
Message 6 of 9
(2,463 Views)
In my opinion, the "File Dialog" is a (the only) useful express VI. You can configure a starting path, default file extension, if you want to force a new file or allow an existing file to be written to/over, etc.
Message 7 of 9
(2,459 Views)
The file dialog was even nicer before they changed it to an express VI many version ago. I am sure that one is still hidden somewhere deep inside vi.lib. 😄
Message 8 of 9
(2,456 Views)
Yes, it works fine now.
Message 9 of 9
(2,428 Views)
