How do I hilight a section of a string array?
I have a VI that displays a string array.  The display is roughly 20 strings high by 20 strings wide, while the arrays in it are much larger.  I am comparing two files to find differences.  When differences are found, I want to somehow hilight or emphasize the block or string that is different.  Is there a way to do this?  Is there a way I can visually hilight one section of my string array?  I looked through the different property nodes, but couldn't find anything to do this.
Thanks for the help,
Jeremy Backer
Jeremy Backer
CLAD
(3,046 Views)
Accepted by topic author JMBacker
Hi JMBacker,
I am not sure if Arrays can highlight only a particular section.
But you could do one thing.
Display the Array in a Table and then chage the background color of those particular cells where the differences are found.
Ritesh
(3,043 Views)
That's gonna work.  Thank You!
Jeremy Backer
CLAD
(3,038 Views)
