How do I implement time stamps with my readings when I import to Excel?
I currently have 3 channels running off of DAQ Assistant and plan to eventuall add more, so far I have set up my code to creat an array send as .csv file, How can I add a column for time stamps for current time?  It is required to know date and time that I am logging my data?  Please help!  Attached is my code  FYI I have a Milisecond delay timer on the THIRD Frame of the case structure.
(2,355 Views)
Hi ChrisR774,
Please take a look at this example: https://decibel.ni.com/content/docs/DOC-14138
(2,330 Views)
