How do I increase the AI gain in Ni-DAQmx Base for PDA?
I posted this question on the Multifuncion DAQ board a few days ago, but haven't had any responses yet...
I'm using a 6062E PCMCIA card on an iPAQ 5555, running PocketPC 2003. I was under the impression that I should be able to increase the gain on the AI channels of the DAQCard by using the task configuration utility for Ni-DAQmx Base. In this utility I raised the gain up to 100, but instead of amplifying the signal, it reduces the dynamic range. Instead of having +/- 5 V range, it has a +/- 50 mV range, and the signal I'm recording is not amplified at all.
Any suggestions?
(2,485 Views)
Hey Chew,
Just so everyone else knows, this question has already been answered by the following post: http://forums.ni.com/ni/board/message?board.id=170&message.id=120004
(2,477 Views)
