08-27-2008 06:28 PM
08-28-2008 12:23 AM
Hi new2this,
the attached picture shows how you can merge cells. If you have merged cells, then you can write values to it, with selecting one of the cells in the merged range.
Hope it helps.
Mike
08-28-2008 03:17 AM
08-28-2008 03:37 AM
Hi new2this,
if you have merged cells, for example A1-A10, then you can select each element from A1 to A10 to insert your text there. In my tests it worked great.
Mike
08-28-2008 05:07 AM
08-28-2008 05:24 AM
Hi new2this,
sorry for the confusion. If the cells are merged, then you have to write into the first of these merged cells. See the attached example.
Mike
