How do I install instrument drivers in folders other than inst.lib?
@JoeWork wrote:
Would putting an "inst.lib" folder under source control help if it isn't part of the absolute path that the library is looking for?
Yes it helps.  BUT, remeber to have seperate repositories for each LabVIEW Rev and bitness.  Often not thought out the first time you set up the SCC and painful to re-organize when you realize you needed to do that.
Message 11 of 11
(651 Views)
