How do I integrate Fuzzy .VI with cRIO 9004?
When I load the .fc file designed by fuzzy logic controller design
 to the fuzzy .vi where connected with cRIO, the error out window
in the fuzzy .vi shows
                                     status          code
                                        X             -1521
can not load the .fc file, but the fuzzy.vi dose not connect with cRIO
in RT application, the problem will not occur, and .fc file can load
to Fuzzy .vi successfully.
                                      Thanks for your help.
Message 1 of 1
(2,703 Views)
