How do I launch an executable?
I'm writing a serial client / server program that will remotely execute an application on the target system.  Only thing I'm missing is launching the exe from the code.  What library / functions can dynamically launch an exe given the path and filename?
Thanks!
(3,184 Views)
Have you tried System Exec?
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/platform/system-llb/system-exec-vi....
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,175 Views)
I forgot to mention. I'm working with LabWindows CVI... writing C code. Not Lab View code. So I don't think I have access to that VI you speak of.
(3,162 Views)
Then you should post to the CVI board instead of LabVIEW.
(3,157 Views)
