How do I listen to a USB port?
I have a separate program running on a Windows Machine.  It transferrs data using a USB port.  Can I monitor the communications in LabView?
(6,630 Views)
Hi exo,
where do you like to monitor? How does the data transfer work?
Mike
(6,611 Views)
No sure what you mean.  My manufacture supplied detector's code sends data from their electronics to the computer through a USB port.  Can I watch the USB port from LV?
(6,592 Views)
And we don't really know what you mean. The USB interface isn't like a serial port interface. You're not going to see a nice sequence of commands. You'd basically see some bytes, depending on which transfer is currently being done. And there are 4 types of transfers on the USB bus: isochronous, interrupt, bulk, and control. USB communication is also in the form of packets.
You may want to start with Intaris's excellent nugget on USB communication in LabVIEW.
(6,579 Views)
I don't know how to monitor it directly, but you might try Snoopy Pro, which monitors USB, and access that via the System exec vi.
(6,578 Views)
I would be happy just to be able to monitor whether or not any information is being sent through the port.  I know the sequence of transfers so I should be able to figure out what is being transfered.
(6,564 Views)
Then snoopy pro is your solution.
(6,537 Views)
