How do I load a vi into a subpanel?
Is it possible to load a VI into a subpanel without having to use the "invoke node" method? That is to say, can I simply drag and drop the little VI icon into my block diagram and somehow wire that so it runs within a subpanel? I've attached a small example.
Thanks in advance,
Chad
(2,751 Views)
Hi chadj,
I'm only aware of the invoke node method.
- Greg J
(2,715 Views)
