How do I locate and kill a process ID?
An application is lauched using the "Automation Open" VI. In order to close the application, I have to use its ActiveX to shut it down. The problem is the the ActiveX seems unable to exit without crashing. Is there a way I could hunt down the process ID in LabView, and forcefully terminate it?
Thank you.
(3,132 Views)
Hi Frank,
Make sure you are using the _Application Quit method when you want to close the application you are controlling with ActiveX.
Kalin T.
(3,112 Views)
