How do I make VISA talk to a HIOKI3651? MAX and GPIB work OK.
I have a HIOKI 3561 Battery HiTester and I can not talk to it with a serial cable and VISA commands.  I can using MAX and the serial cable, and it will work with GPIB, but I don't want to purchase a GPIB for every tester.
I am using a basic VISA Write and Read and all I get is a read error and either nothing in the buffer or the command is bounced back.
Does anyone have any ideas?
Ben P.
Message 1 of 11
(3,878 Views)
Can you talk to it using HyperTerminal?
If so your should be able to talk to it from LabVIEW using the same COM port.
How have you tried to talk to it using VISA?
Omar
Message 2 of 11
(3,873 Views)
It looks like you can get it to work with MAX, right?
If so, then it should also work using VISA.  Did you make sure to use the same baud rate settings, etc?
http://www.medicollector.com
Message 3 of 11
(3,866 Views)
Also, did you try testing this free software:
BATTERY HiTESTER 3561 Data Capture Software:
http://www.hioki.com/download/soft/3561/3561_e.html
Might help determine if its a HW or Sw issue.
Message 4 of 11
(3,863 Views)
Details, please. What is the error code? If I had to guess I'd say you don't have the termination character set up properly for knowing when to stop the read operation.
Message 5 of 11
(3,857 Views)
I just made a simple VISA Open, Write, Read and then made the same GPIB series.  The VISA didn't work and gave a read error.
When I open MAX and the test console I can execute a write and then read and I get good numbers from the meter.  I also get good numbers from the GPIB commands.
The error is non descriptive and nothing is found when I search it.
I have tried using no termination characters and using a "\n" in the command line.
Thank you for the ideas.
Ben
Message 6 of 11
(3,851 Views)
Maybe you should post your code with screenshots.  It would help us to help you.
Message 7 of 11
(3,847 Views)
What VISA Read Error?
Omar
Message 8 of 11
(3,844 Views)
Still haven't told us what the error code is.
Trying randomly is pointless. What does the documentation for the device say that you should use?
Message 9 of 11
(3,832 Views)
The error code is "-1073807339" and the source is "VISA Read in VISA HIOKI 3561.vi"
The manual has a "\n" as a termination and I tried it with this and without with the same results.
I don't have any custom parameters in the vi.  Do I need to add some?
This vi works if I direct it to a GPIB cable, and a vi similar to this with GPIB write and read also works.  It just doesn't work with a serial cable.
Thank you for the help.
Ben
Message 10 of 11
(3,795 Views)
