How do I make a hyperlink in labview which links my text to a file folder on the desktop
I have yellow text boxes explaining my code in labview and would like to link C:\Users\Brett\Desktop\Chemostat Project 5-21-13.
This would be easier for the user to just click the text. Instead of looking it up.
jakers
(4,450 Views)
jakers
hi jakers,
are you looking for a tooltip?
You could use the context help!
This article is about documenting your code regarding to wires:
http://digital.ni.com/public.nsf/allkb/D410C0E5A4763B5886256D49005454F2
(4,444 Views)
Jakers,
I don't think you can create links in comments. However, if you want to go through quite a bit of work, you can create an XNode that will do it. XNodes are NOT easy to do and I have not been very successful at using them, but it is the only way I can think of to get the feature you are asking for.
This link helps to explain xnodes and has other useful links if you decide to create one:
http://forums.ni.com/t5/LabVIEW/what-is-an-xnode/m-p/1307516/highlight/true#M537812
Much easier would be to include instruction to copy/paste a link into a browser.
Good Luck,
Bob
(4,400 Views)
Accepted by topic author jakers
Already been done Smiley Happy
https://decibel.ni.com/content/docs/DOC-15362
Cheers!
(4,397 Views)
I thought I had heard of this and I am glad to see that it is already built. Yes, I would heartily recommend the XBoxes as described in that link (and I plan to use them as well).
Thanks for the link.
(4,371 Views)
