How do I make a routine stop and start again without restarting labview?
I am running Labview 6i and am somewhat of a noob.  I have a subVI designed to take information and write it in a file, but every time I stop this subVI it will not start again until I restart the entire VI.  I would like to be able to start it and stop it and take multiple readings because I must leave the main VI running.  The subVI is attached.
Message 1 of 8
(3,519 Views)
Hi Jiggles,
you can restart it in your main vi you can add another loop to your sub vi or you can insert a case structure with stores all x iterations your data to the file without stopping the loop.
Mike
Message 2 of 8
(3,515 Views)
I tried a couple of case combinations, and this one seems the most solid.  Still, the while loop is not passing information.
Message 3 of 8
(3,507 Views)
Accepted by topic author Jiggles
The while loop isn't passing information because it's still looping (you wired the continue terminal to a True constant).  Loops don't pass out any data until they're finished.
If you attach your main VI as well then we can help you correct both of them to make them work together.
Jeremy
Message 4 of 8
(3,496 Views)
Jeremy,
Wow, that was boneheaded of me.  Unfortunately, the main VI is at work and I cannot get to it right now.  The random number generator simulates the data coming into the subVI.  The except for the data input, the subVI is autonomous.
Message 5 of 8
(3,488 Views)
Not a problem.  What exactly is that data that you are passing to the subVI.  Is it an array of doubles?  What exactly (in words) do you want the subVI to do?
Jeremy
Message 6 of 8
(3,486 Views)
Thanks to prodding from you, I believe I figured it out.  Please have a look.
Message 7 of 8
(3,482 Views)
Great!
Have a nice day.
Jeremy
Message 8 of 8
(3,478 Views)
