How do I make an event occur once and only once upon a button press in Labview?
I have run into this issue several times now, usually with sql database entries. The button is wired to the selector on a case statement which is inside a while loop. The loop executes rapidly (it must, for my appliction), and so the case statement executes many times when the button is pressed.
(2,538 Views)
All you have to do is change the mechanical action. Use Latch When Released and the button reverts to the old value once it is read.
(2,538 Views)
Without seeing your VI, my first thought is you need a FOR loop, with a "1" for the amount of iterations - perhaps connect your case inside the FOR loop with N=1. Your FOR loop could be accessed via a Case, or use compare logic VIs along with your booleon button to initiate it. Good Luck, Doug
(2,538 Views)
