How do I make and save a new color palette?
How do I make and save a new color palette? I do not want to use one of the 5 that are available as standard palettes but would like to customize my own. Thanks
(2,583 Views)
I'm assuming you meant "controls" or "functions" palette instead of "color" palette, judging from your comment above about the 5 palettes already available. Anyway, you can search the LabVIEW on-line Help for "palette" and several topics will come up, most noteably "Creating and Editing a Palette View", which will help you get started designing your own palette or sub-palette.
And if you *were* referring to color palettes, there is an example on the NI Developer Zone (www.ni.com/zone) entitled "Customizing Color Palettes" that should help you out.
Good luck with your application, and have a pleasant day.
Sincerely,
Darren Nattinger
(2,583 Views)
