How do I make my error source look like standard LabVIEW codes?
I have my error codes stored in an *-error.txt file.  I'd like to format the error source so it looks like a typical LV error source.  I've tried using an error code to error cluster and then either a simple or general error handler and I only get the error code, but the message has all the stuff I need.  I don't want to wire the message to the source, because that's not how LV error codes are normally displayed.  Am I making sense?  LV 7.1.
Bill
Bill
CLD
(Mid-Level minion.)
(3,038 Views)
Is it possible for you to post screenshots of what you are seeing and what you are expecting? What you have written is a bit confusing.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,012 Views)
Yeah, I understand.  I have a vague question and I have to have help from you guys to even formulate it correctly.  Thanks, I will get back here soon!
Bill
CLD
(Mid-Level minion.)
(2,997 Views)
