How do I make my waveform send one point per iteration in a loop?
I am trying to create a demonstration/lab for a future course at my university.  I am trying to send data from a wind turbine to a third party DAC in order to run a motor.  I have found out that when I send a wave form to the DAC I must send one point per iteration if I use the arbitrary signal generator.  I would like to be able to send a file to the DAC without manually loading it as the arbitrary signal generator does.  I was wondering how to send the data using one point per iteration using the build waveform or other waveform function that can have the waveform built from a file that is added on the front panel.  I am using labview 8.0.
Laura
Message Edited by lhoising on 03-30-2007 01:21 PM
Message Edited by lhoising on 03-30-2007 01:25 PM
(2,666 Views)
Maybe I am asking the wrong question.  Maybe I should be asking why it is that when I send a waveform to the the DAC (using active x controls) the signal that is sent to the DAC is just the final value.  I probed the wire connected to the data input of the DAOUTPUT node and it shows the entire waveform graph and not just the last value.
Laura
(2,650 Views)
Hi Laura,
I'm a little confused.  Could you post your VI so I can take a look at it?  It may be the case that this is just a limitation of the device driver that you have.  However, if I see something wrong with your VI I can help you out.
Justin D
(2,606 Views)
