Hi Lynn,
The oscillation frequency is more or less stable. At this point, however, I do not know how stable the phase shifts are.  I did consider using fisheye lens, but I have optical access limitations. And you are right on point when you say that  it might not be meaningful to compare the phase of at time t1 and position z1 to another time and position.
This is what I am thinking. Use two PMTs aimed at different heights in the flame and acquire both signals simultaneously. Now I am using a PCI-6221 which doesnt have simultaneous sampling capabilities. I am considering using a PCI-6143 with an SCXI 1125 (for amplification) on an SCXI 1000 chassis. I think to even compare the phase you have to do the acquisition simultaneously.
What do you think?
