Hi everyone,
I have an application with 8 scopes on it and the data displayed on the scope is selected by a drop down menu which is an enum control that is a typedef. Since this application interfaces with different hardware, I need to be able to change the text in the menus (that is, the data items being displayed) programattically. How can I do this? I don't necessarily need to change the basic enumeration data typedef, but I do need to be able to change the text items within the instance, and I need to be able to do so by index - that is, if there are 10 items in the typedef enum, I need to be able to modify the 3rd one, for example. Also, I may need to add some or remove some. Any ideas?
Jason
