How do I monitor serial port activity without first sending a command?
In my application I am sending a command through the serial interface and I want to monitor the response. The response is not instant, in fact it is a timeout response indicating the requested action did not work. How do I monitor so I can parse what is coming in over the serial port without necessarily sending a command?
(2,982 Views)
Use the Bytes at Port property to determine how many charachters have been received, then read that many bytes. You can also set up a timeout on the read functions. One of those or some combination should be able to do what you want.
Lynn
(2,971 Views)
You can always place a loop where you monitor the number of bytes at the serial port.
After configuring your VISA serial port session, you can create a Property Node to get the number of bytes available at serial port.
You can then process this information, for instance:
1. Establish a timeout because you never get a response.
2. Do serial port read if there is data available.
You can exit the loop with a timeout condition or having processed the data.
-JLV-
(2,970 Views)
Thank you for the responses. I figured it out a little later using the techniques described here. It is working fine.
(2,957 Views)
You could alternatively use VISA events on the Windows platform.
See the following document for more information.
http://www.ni.com/pdf/manuals/370132c.pdf
Message Edited by Conseils on 05-11-2005 08:14 PM
(2,955 Views)
