How do I move one co-ordinate to the other on X-Y Graph?
Hello Everyone,
Let's say first co-ordinate is (5, 5), I want to move this pixel on this X-Y graph to (10, 5); how can I do it?
I know that I need to increase it slowly by step of one towards the right on x-axis, but how can I do it with it showing every step and ending up at (10, 5)?
For example:
First Step
o   <----- pixel
Second Step
  o
Third Step
      o
etc..... till final step at (10, 5).
Thanks in advance for helping!
Message 1 of 16
(3,570 Views)
Hi jqlee,
you just have to add 5 to its X coordinate, then plot again...
Message 2 of 16
(3,562 Views)
If you want to show the pixel moving, not just the start/end points.  you will have to utilize a loop where you add one each time (or a fraction for a smoother movement) and a wait timer to ensure enough time elapses for the user to view the change.
Message 3 of 16
(3,547 Views)
x=xstart+frac*(xend-xstart)
y=ystart+frac*(yend-ystart)
frac=fraction of the way between start point and end point, 0->1.
frac=(current time-start stime)/(end time-start time)
loop over time in small increments.
Message 4 of 16
(3,544 Views)
Thanks everyone for helping!
I am able to reach the end point of my second co-ordinate, however now I wish it to move down the Y-axis after it reaches the end of second co-ordinate.
I used a case structure however it is giving me a hard time (also because I am unfamiliar with it).
Is there any simpler methods other than case structure? If not, how do I use it to continue the flow down the Y-axis please?
Message 5 of 16
(3,509 Views)
Hi jqlee,
either use a (more general) state machine approach or some modulo math involving Quotient&Remainder...
Message 6 of 16
(3,504 Views)
Thanks for your reply, GerdW!
Let's say if I want to just allow the user to choose the four corners of a rectangle, and then for the pixel to show one at a time and end back at the initial point; should I use Enum, Boolean or Numerical case?
Message 7 of 16
(3,499 Views)
Hi jqlee,
you don't need any case structure at all. You need an array of points and a FOR loop to iterate over the array...
Message 8 of 16
(3,492 Views)
REALLY?! If that is true, I will be so so happy!!!
I will building all four directions now and I will try your solution!
Thanks for your post!
Message 9 of 16
(3,490 Views)
Let's say for my .vi as shown below, what can I do for the "N" at the top left corner for the pixel to complete a round; repeating the cycle again and again if possible?
Thanks!
Message 10 of 16
(3,485 Views)
