How do I pass an array of strings? (Help Me... Please!!! .Read Me....)
Dear All.
Help Me...
English is not very good. Google translator is used.
Please refer to the VB program
Private Sub m_btn_Click()
    Dim nReturn As Long
    Dim sPpid As String
    Dim sMdln As String
    Dim sSoftRev As String
    Dim nCount As Long
    Dim saCCodes(2) As String
    Dim naPCount(2) As Long
    Dim saPNames(10) As String
    sPpid = "PPID001"
    sMdln = "Mdln"
    sSoftRev = "Rev001"
    nCount = 2
    saCCodes(0) = "1"
    naPCount(0) = 5
    saPNames(0) = "Param001"
    saPNames(1) = "Param002"
    saPNames(2) = "Param003"
    saPNames(3) = "Param004"
    saPNames(4) = "Param005"
    saCCodes(1) = "2"
    naPCount(1) = 5
    saPNames(5) = "Param006"
    saPNames(6) = "Param007"
    saPNames(7) = "Param008"
    saPNames(8) = "Param009"
    saPNames(9) = "Param010"
    nReturn = m_XGem.GEMReqSend(sPpid, sMdln, sSoftRev, nCount, saCCodes(0), naPCount(0), saPNames(0))
    If (nReturn = 0) Then
        Call Me.AddMessage("[EQ ==> XGEM] GEMReqSend successfully")
    Else
        Call Me.AddMessage("[EQ ==> XGEM] Fail to GEMReqSend (" & nReturn & ")")
    End If
End Sub
nCount, naPCount enough saCCodes, saPNames value must be sent.
How to handle an array of strings in LabView is impatient.
I want to VB program implemented in LabView.
(3,646 Views)
you handle an array of strings the same way as an array of numbers Smiley Wink
There are a lot of functions in the Array palette!
Please be more specific on what you're trying to do.You want to pass an array, but what's the target?
And you don't need to cry in the thread topic!
(3,643 Views)
Qestit Systems
Certified-LabVIEW-Developer
(3,632 Views)
Sounds like you need to read some of the LV tutorials:
http://zone.ni.com/devzone/cda/tut/p/id/7571
http://www.medicollector.com
(3,618 Views)
psCCode, pnParamCount, psParamNames is StringArray.
The first pointer to an array of string values I want to pass.
In the first string of EXGemVb GEMRspPPmt should proceed with an array value.
VB program, the value of the results is attached.
(3,586 Views)
GEMReqPPFmtSend is a description.
GEMReqPPFmtSend (sPpid As String, sMdln As String, sSoftRev As String, nCount As Long, psCCode As String, pnParamCount As Long, psParamNames As String) As Long
Parameters
Name ,               Type         desc
sPpid ,               String ,     Process Program ID
sMdln,               String,      Equipment Model Type
sSoftRev ,          String ,     Software Revision
nCount,             Long,        CCode Array of Count
psCCode,          String,      CCode Array of the first Item pointer
pnParamCount,  Long,        ParamCount Arrayof first the Item pointer
                                         Parameter in the CCode gaesuim each ParamCount
psParamNames,  String,      ParamName Array pointer of the first Item
                                         ParamName the ParamCount Array of Array Size Total number of information is the sum of all.
(3,566 Views)
Have you actually tried to right click on the according node parameter and select Create->Constant or Create-Control??
And I don't see any string array in the parameter list. That are all simple strings and the VB code in your first post clearly shows that the call to the function only indexes the first element of those arrays to be passed to the function, not the entire array.
If the function really reads arrays despite being declared as only taking strings then it is using some weirdo VB trickery and there will be no way to replicate that in LabVIEW.
Rolf Kalbermatter  My Blog
(3,561 Views)
