How do I pinpoint the program execution?
Hi all,
I am wondering how to pinpoint the program's execution point?  I have a problem with all of the loops not stopping properly.  I hit the "Hilight Program execution" and it went to one loop, that is, it appeared greyed out, but I can't figure out which case it's stuck in.  Is there a way to find the exact *point* of execution?
Jason
(2,810 Views)
You can use breakpoints. The program will pause as soon as it hit the breakpoint. To add breakpoints, right-click in the place where you want it and set it. You can also set probes. The probes activate as soon as the information is available. Then you can be creative with the highlight execution, breakpoints and probes. You can have a fairly good idea on how your program is executing.
Otherwise, try posting your code or an image of your code so we can try to figure out what is going on.
www.vartortech.com
(2,802 Views)
