How do I plot something other than time on the x-axis? (i.e. Voltage vs. Current)
I'm trying to make a plot of Current vs. Voltage instead of either vs. time and eventually adding a third dimension as well. Is it possible to do this??
(2,937 Views)
You can use xy graph to graph voltage vs current, but don't know about third dimension, perhaps if you are using LV 6 this is possible, but in LV 5 you'll need a toolkit which i don't know if exists.
Hope this helps
(2,937 Views)
No matter if you are in LV 5 o r 6, just look in the Search Example help window, chapter Fundamentals / Graph and Chart, and you will find examples both for XY graphing and for 3D graphing.
Roberto
(2,937 Views)
