How do I print a huge VI hierarchy to a large format printer/plotter?
I need to print a very large VI hierarchy to a large format printer/plotter. I have played around with just about everything in the page setup but all that will print is the header. I can successfully print it on a "regular" printer, but would have to cut and tape many pages together.
Is there a way to save the VI hierarchy to a common file format such as PDF?
(2,653 Views)
Could you use pdf995 to intercept the print output and save directly to a pdf file??
(2,643 Views)
