How do I print a multipage doc to PDF from LabVIEW?
Yes, that does look promising. I have passed it on to my client. Thanks.
Steve Bird
Culverson.com
LinkedIn
Message 11 of 14
(1,426 Views)
Try Pdf995. The suite includes PdfEdit995 which allows you to combine pdf
files. It's free if you don't mind ads, or $20 for a suite key to avoid
ads. Pdf995 does a good job creating pdf files. It's what I routinely use.
I haven't used PdfEdit995, though.
Message 12 of 14
(1,421 Views)
Purchase a decent PDF writer such as Adobe distiller this allows you to 'Print' as if directly to a printer. This then deals with the making of the PDF.
Message 13 of 14
(1,393 Views)
I have not tried this, but it may work. Print your VIs using the PostScript option and set your printer to save to file. This will give you a set of PostScript pages. Use GhostScript to assemble them and write them out as a PDF. GhostScript has a command line interface you should be able to automate from LabVIEW. It is also available on several platforms. You can get it here: http://www.cs.wisc.edu/~ghost/doc/AFPL/.
Message 14 of 14
(1,373 Views)
