How do I print topics from Labview Help without the rightmost text being cut off?
I'm trying to print some topics from Labview Help Version 7.0 but the rightmost text gets cut off. I've tried different printers, different computers, and different print options. Nothing seems to help. Any suggestions?
(2,672 Views)
Hi Tim,
Actually the Help window you are seeing is not a National Instrument product but the "HTML Help Control" provided by Microsoft. You can check the version of the "HTML Help Control" by right-clicking the top of the "LabVIEW Help" window and choosing "About HTML Help...". The version that works fine on my machine is the version 5.2.3735.0 (see attached LV70Help.jpg). Please check the version of your "HTML Help".
How do you choose to print? Do you experience clipping when choosing the "Options > Print" option (see attached PrintHelp.jpg)?
There's a Microsoft KnowledgeBase describing a clipping phenomena:
http://support.microsoft.com/default.aspx?scid=kb;en-us;302505
Is this the same issue you are experiencing?
Philip C
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,672 Views)
